Below are the keyboard shortcuts you may want to familiarise yourself with.
| KEY | FUNCTION | |
| Tab | - | Open Toolbox |
| S | - | Open Selector |
| Spacebar | - | Orientations |
| Ctrl | - | Multi Select |
| Alt | - | Toggles between rotate and translate |
| Escape | - | Clear Selection |
| V | - | Toggle View Mode |
| A | - | Toggle Assembly Selection |
| H | - | Toggle Selected Visibility |
| I | - | Isolate Selection |
| T | - | Toggle Triad Visibility |
| / | - | Select Instances |
| + | - | Increase the rotation snap |
| - | - | Decrease the rotation snap |
| Home | - | Activate First Step |
| Page Up | - | Activate Next Step |
| Page Down | - | Activate Previous Step |
| End | - | Activate Last Step |
| Delete | - | Delete Selected |
| Ctrl + Z | - | Undo |
| Ctrl + Y | - | Redo |
| R | - | Restore Default Position |
| Shift+R | - | Restore Step Position |
If you have any suggestions for more to be added then let us know.
