Project size limit
Is there an upper limit to the size of a project? I recently tried to upload a project similar to ones I have loaded in the past, however it won’t load all the parts. Specifically, it won’t load the wall and floor, which have loaded in the past. I am also getting an out of memory error message. The project size is slightly over 130Mb
We do have an upper upload limit for neutral formats such as OBJ and STEP files.
This upload limit would stop you from creating the project in the first place, so it wouldn’t upload some and miss files.
We have no limit when using the addins.
Where are you getting the out-of-memory error message?
Are you able to share the files with us to investigate further?
What is the maximum size of a solidworks file?
We dont limit the size of assemblies you can upload via our SolidWorks addin.
Bare in mind though, if you are intending to make an interactive 3D presentation, which may be viewed of all manner of devices (even low powered phones for example) then the size and complexity can have an impact on performance.
