Re Anchoring a label to a newly imported model
I recently discovered that I used the wrong model and needed to update with the correct one. It mostly worked fine except the labels (as expected) were no longer anchored to the parts. Is there a way to re-anchor the label to the new model?
Hi @user6388, If you drag and drop the leaders target this should reattach the labels to the component you drop it onto.
I have tried doing that many times. They will not reattach. The part will highlight in the same way they do when a new label is first created, however it won’t remain with the object when the camera is moved.
@user6388 can you private message us the url you see in the browsers address bar and we will take a look? if you could also let us know the step name which has the broken labels that would be useful.
Closing as this was resolved via Support some time ago.
