Semi-transparent circle border on export (WebP)
I’m seeing a visual bug when exporting images from Cadasio: the circular border of my Detail View bubbles gets a semi-transparent halo in the exported file, even though it looks perfectly clean inside the Designer editor.
This is a recent issue — it wasn’t happening before on my previous exports.
What I’ve tested:
  • Looks fine in the editor itself — sharp, solid circle border.
  • The halo only appears after exporting to image.
  • Export format is WebP.
  • Happens with every Render Style — no difference.
  • Happens without any scaling of the detail view (freshly created, not resized).
  • Not related to background transparency — tested with opaque background too, same result.
Screenshot attached, arrow pointing to the affected bubble border.
Thanks!
Update — I think I found the root cause.
The captured image inside the Detail View bubble is not properly clipped to the circular mask — the rectangular image content overflows past the circle edge (see screenshot). This overflow is likely what’s causing the semi-transparent/hazy look on the border I described above.
Hi @user5103 ,
Thanks for logging this. The team is investigating the issue and hopes to get a fix out for it asap. We will update this post when its done.
