I’m having an issue when I import a Step file. I’m using Rhino 3D and have named each object, export as step (which contains each object name) and then import into Cadasio. But when I goto the Selection Trees and then the CAD tab in Cadasio all the objects are listed as SOLID. I really had hoped the object names from the step file would load into Cadasio to make it easier to adjust visibility etc.
Any thoughts on a solution?
