I have gone back and updated some steps within a guide on the desktop mode. However when setting the mobile views the steps are different. How can I get these to be the same without manually editing the steps to match?
Desktop:
Mobile:
Can imbed a second you have to trust me they’re different.
Thanks,
Josh
Hi @user6150 ,
Hopefully I have understood your question correctly. If you are wanting to reset a device to match the main(desktop) you can do so using the icon on the devices tab…
This will clear out all properties for that step on that device.
If you want to just reset a particular object then have it preselected, go to general, then use the delete properties icon…
Hopefully this answers your question. If not let us know.
Also, in case you haven’t seen it can I recommend our device’s tip video…
