Unable to remove device properties
Hi there, I’m trying to apply updates to an instruction we made around a year ago. But we’re having trouble getting our changes to stick.
I’m aware of how device properties work, I’ve deleted all device properties in all steps by selecting the device and using the toolbar. But this doesn’t work properly.
After this there are still objects hidden in the device view even though they are visible in the default view.
Whenever i try to remove all device properties by selecting the objects it gets stuck and loads forever forcing me to refresh the page.
This is preventing me from properly updating our instructions and i would rather not remake them from scratch if possible.
Any help would be appreciated.
It appears that I am able to remove device properties from selected components as long as I’ve selected a device.
This fixed my issues for now.
Removing device properties from components in default mode still results in an endless loading screen though. Perhaps this is a bug and shouldn’t be an option in the first place?
Hi @user7196 ,
Just to ensure I am unstanding the issue correctly can I clarify, are you pressing this button when a device is activated and its getting stuck?
No it’s the other button, whenever you select a part under the general tab.
This works when a device is selected, but gets stuck when in the default view. (just tried it again and still does) I’d assume if you’re in default view it deletes all device properties of all devices from selected components.
